Hello,
I've done quite a bit of reading here and on other sites as i prepare to fix the center stringer and replace the deck in my 1959 Glasspar Seafair sedan.
I've never done the glassing before, but feel generally ready to start. That said, i was hoping to confirm a couple of questions that I am still unsure of.
1. For the stringers, it looks like the best bet is the 1708 Biaxal. If i set them in and run tape along the seams, then the Biaxal is all i need as far as fabric?
2. For my resin i was looking to use the '700 vinyl resin', which seems to be a step up from the standard polyester, but not as prohibitively expensive as the epoxy(which would be out of my price range). overkill, underkill?
3. I am using marine ply for both the stringer and the deck. Do i need to seal the stringers with resin before glassing them in? I am reading a lot of conflicting info about this.
4. For the deck, am i ok with a couple of layers of 6oz matt on each side? What are the thought on sealing the screw holes with resin before screwing them in?
Thanks a lot!
Ian
Thanks a lot!
Ian
