No Title
Fairing, fixing, sanding, priming, repeat
fairing, fixing, sanding, priming, repeat......
I've been doing a bunch of cosmetic work on the interior pieces(splashwell, dash, cuddy inset). This boat originally had the steering on the port side, so switched that. The splashwell below is one i found at my friends boat yard, and required a good deal of renovation. I think i'm finally saying its done and ready for final sanding and painting. I painted the cuddy insert first to see how the paint and application would hold up. I'm pretty happy with it! I'm using the Marshall's Cove paint, which is an enamel based single stage. It came highly recommended. I was originally going to roll it on, but with all of the curves and indentions in these pieces, i decided to use a Prevast sprayer. After a couple of passes i got the hang of it. I did really light coatings with repeats every 15-20 minutes until i got to what would be a solid "first" coat. This is what it looks like. I am going to spray the splashwell today, as well as the two dash pieces.
If i have time, I'm going to take a stab at rolling some gelcoat on the transom. this will be my first try and I've been reading up on the process. I figure if i screw up its a small enough area that it won't kill me to start over. My buddy comes over next week and we will gelcoat the hull.
In all of the fairing, i went through a couple of products. I really like the 3M Marine premium filler. It is easy to use, sets up quickly, and has made my fairing/sanding go a lot smoother<g
