Re: 1987 Chris Craft Amerosport 284 Recondition Thread
Kyle,
In regards to your shower sump, if it is anything like mine, it is merely a small bilge pump with direct access overboard. I'm unsure if they made shower sumps that would go to a holding tank, but mine is just in the head floor (below a teak removable panel) that is turned on by a switch in the head, and has a direct shot overboard.
My forward most bilge pump sits just in front of the aft cabin area, maybe 2-3'. I think the idea is not a lot of boats will collect water forward of that, as they naturally tend to sit stern down.
From what I gather, in order to get the fresh water system to "taste right" it's a bit of work. Think of it like a pool, the tank, especially if not used, or winterized, needs to be flushed numerous times, and most likely with cleaners. Then I'm under the impression the water in there should be replaced often, and possibly treated. My fresh water tank is full now, and I use it for dishes, brushing teeth (bottled water for anything that hitsmy mouth though) washing up etc... I avoid ingesting it at all costs.
The gear shifts on mine are positioned like this. On the right side (starboard, for those nautical guys) I have two side by side levers. These control the engine throttle. On the left side of the helm (port of course) I have two side by side levers. These control the transmissions.The right side controls sit at the bottom of the lever arc (idle for the motors) and run to the top of the lever arc (WOT). The left side controls sit in the center of the arc (nuetral). I push them down for reverse, or forward for... forward. When docking, assuming little wind and current I either turn my body towards the boats center, and use jusy my right hand on the gear shifters. Other times I will stand with my back to the helm and use my right and left hand while standing in front of the gear shifters. If I need any RPM, I again use one hand, put it in gear, then apply the amount of the throttle I need, back to idle, then out of gear.
It all sounds confusing, but once you get to used to it, it makes sense. Some boats have the throttles/gear levers in different positions as well. I thought I had a photo, but my photos appear to be half gone from Photobucket...
