sphelps
- Nov 16, 2011
- 11,435
I would just stick with polyester resin . Thats probably what you used before ... You will be doing wet on wet layups if you can .. The resin should be the unwaxed kind .. The bondo stuff at the box stores has wax in it ... Is there a place in town that deals with glass ?
The thin metal cutting blades for your angle grinder work really well for cutting fiberglass . It won't shake everything to pieces like a sawzall will sometimes ...
