1978 Sea Nymph SS160 resto
Watermann
The target date has arrived for my 1978 Sea Nymph SS160 restoration. She had a half way done resto a decade ago and now is need of some serious work, including some maintenance on the Johnson. Here is my walk around video in glorious 1080p.
Watermann
Re: 1978 Sea Nymph SS160 resto
Pics of my SN 160 on first day of tear down.
y4me81NdBoPdO6eHcArzFr4OtRhfRm_tZ6vuRJ2kEGRYYhWdz88VBuvTDcdWfN8tYhgIZqpd-Hf9fNm5acGiV7BQJ0-aBMeYD2IFOx9FAaJ6VTajo5UN2UHCxBpxmBfi98T3lARB4hpsm4Yirzrn6QEL5KlEKvYceyzxKHmbyvWRknsiGzWV_HoAs6V-flZn-y4OMwOhSL9Wx6QnwGu-1PGDQ
y4mZ6u2f9siCFRDawDAVIhwgpbDg237iOneZd1SVWZvjqbr_O7tqvtzV4uqXW5ea056Lf3eoJjPC15JcSs4Dm-3pILOfQl2ak7Urw1bQKeoZI1TewRJjivSpXdCUUOemV_ChPQhyvJV4ekVT6fXM85JE3EU_QLaHk9zbM66Vm7itWX-ssIR7aKxKcdlGuDaj-Q3m-fzyB970hW8J65pDaGPeA
y4mVZC38UiplQi61Sp4OQVIPlcQTI_unTikN65cobLtYzkZM5DWz9rC7xiR_hpGyl_92e8wEEhdPNeFf_rvFXOBp7-6Lh7bT__SmQeIS8FsxNL-shAORZBltpCEu_DtE_UtRqJEQEmkxVddBwkIfhJSvyZWLCxP1jmr_YU_c21mu-oSMaKHxOeEjzRjXZc3yXDyKFPIy4TsarcZ6ZBEdPKwnA
Building the motor stand inside the garage with forced 220 heat and my helper.
y4mcrylvkaYZB_Q7khIBdV6F9VUoiH8u73F-yMX7-VDEsFGYGaYDYUlHeY-BjAbg6N0GPctrI01i-SOZjnYb_yOCqiNyNbGcP-vXrdBxYFmZBNHiQ8BhCoHhyXx66EwP1ZmjU1K4aUCsk-D6VSBcAg6cGS5cQ1LUVHGdSf5hhgG4Kt8laE6ulSB8gPuXy1JayJksRix2kVIjBUo9aW_p55BJA
y4moDqlQsnZNImX6dE4tYq7pA1RIhvgj-1qzgpJPEbWYaWbmJHopXWom8aNlPpREiFYsHnotmVaWE8XFZPhXHW1oBX2gid4pXNx93mB1FIKIZsCotDpAXFN1bH1d34aveXnoLmCpoFCGGBlx9qRnYTYdwDHzecQLqM68pXHdHoefoDQUCdHXW6iJ_mDJg9vBqdXNDLF9tjg2iYtyDgcPhanAA
End of first day tear down job.
y4mvvPV1Zf-bq3Wmsf2HIAXUtCgFMlKjOHoo7441Zz58xEKonYwRV7oXKtmeyWbEl7zqt-5Fu409-xiqvCQ5R0k3d7K5Er0yEcNzzamTUQL4kke6RrCvYZJC684oYaId1VmeStELqasjgshfAejbHnSvi71-ip15PfCbX1_sl9ID_D8PpqKScpnf67Q_qq5Oz1-k7MdEHfKwP4QaVB3Zy5ohw
y4mAz6PB9_xhXUqVKTS8PXm3Wz4tj_o-Wnn-AilCIiW5fAorbU9lHT3OCK00jt1sB1JRJM3lQDSrGtDnVWd5YbZdyB9MWlVOmfdPo4G1TpwU5qQlTa2yFA3uoKaGfN_1CHt4pPhfygsxkR55On2RjVSyYMu3lAZJeZ2NKhDS5KNYJIw5UXVsqvGVovdW5H71c-3bgnGjzLC7imK7zibbLYX9w
jigngrub
She'll fix up real purdy.
What's all that white stuff all over everything? Some kind of volcanic ash? Did Mt St Helens blow again and they just haven't reported it on the news?
Watermann
Thanks, I sure hope so...
Nasty stuff is over a foot deep and I'm sure tired of it. Thinking about kicking the wife's Buick to the curb and backing the boat inside. Not sure if I need more problems tho...
Watermann
Today I was able to get the back deck off, all the pumps out and the transom removed. Then went to the lumber yard and got my special order 3/4" 7 layer marine grade ply. I've never seen plywood like this before or paid as much either for that matter. After seeing my 35 year old original transom was still in fair condition (although getting soft) I'm thinking the new wood will be far stronger. After seeing both done here, I decided to use glue to laminate the 2 pieces of transom ply rather than epoxy resin, mainly the cost and ease.
y4maHtzzcBFf7wYzAGgbieqP1Km9f-DFljvxhzsBcnLFrkmpxzn5TisA1z1fS_inBaTrPf9S8zujCG2mRY_uGFXo931VwzKumXgieaRw2ebtkiKdXk5ePQIGrxQcqednDoG1DoMMoY74O93TWg_CWyNQUDCkEGRYMIxOtalqAdkpUcjBQbSzvkp2qLzg4kEloC50xtMQJgBoEA6ZFKMWHOKuA
y4mrWpb8iaZ8IM8MnIZVyeqz1_Tfdmu_7JWqVUinEFskm6iB8cXc7-Tx4pFI9vBzWtlnqboBWTI2-Zbz5MqLdy0atgJZdYb3qkqV2hM6foQdCjgq8R3MQKiaASyksIOHDqrj8MUasd3Ip9XdB7GumG5j2olaz6Yl3lerj3Z73HBarJKYPFPpjlBxmuGANgl3vjUaf1qFhiGiDw2l68yj7jmuw
y4mdOKkXp_AmbTyu7Bo0V6GRNQYJ6idjcs8937P--rOON70yPnXqdYO68hAJG88FTeVhXaNF6TwTqXuG99T9dWtLnYiICiQN1i3mUEcJaYYiW--3riUUr_GKxT9TvWiZR0ha-bV0Fm4J5NLxF-gIoOcF68enz4un4ER7boqU0qMC_COG-LqJ7s5B7ChwwhaZ7A9IXbQDLD1C2f7ymVQwwYbIg
y4m1zAf1kizlGXMobu_NhuAxVb3T3VTkmUM_6msX2I0v4CEMGQWlrVDyESRqnFgCejlHG1yUgTyksyQGtQL0RO_4sC-fCZC28jZPFwMagxqsWRJXn0rf6D-k-NqQ8M59wtKx2oea_klbvRsJbD3fPlWhFHIMk2P5cxwQ-pCMZzos3pKWWqqsSbp-jPAkvYTesIDyGOBr2vpEI-FBesep4mGpw
jbcurt00
That glue looks like it's a product that's similar to Gorilla Glue, make sure to clamp AND screw the 2 transom layers really well. The glue is likely to foam & expand as it starts to cure. And do your best to keep it off everything you don't WANT glued. :)
The marine ply look great, better 'cause it cost ya.... good work so far
Bomber Goober
I used Gorilla glue to glue my transom and just my .02 worth, but you might consider getting more than that one bottle if you didnt already. I got the 18oz bottle and used just about the entire bottle. I screwed from the outside inward in like a spiral pattern, still had some oozing but when i cut the transom to shape i had a nice even layer.
Streetgang
H20 Man,
Congrats on opening your thread. What a good looking boat!
You mentioned a halfway resto about a decade ago, just curious how long you have owned her?
After seeing all the rotted transoms I am amazed that both yours and mine were in such good shape. I agree you are doing correct thing though by replacing.
I'm thinkin that 55 on the back is just about at max hp for boat and am guessing it flys.
Very nice.
Watermann
H20 Man,
Very nice.
Thanks SG, In 2003 I picked her up for $1200 and have enjoyed many hours on the water. I fixed up some bad decking, did some carpet and bought new seats when I first got it, hence the half resto. The max according to the hull plate is 70 HP but the extra weight of the 70 to add 15 HP would be just about a wash I'm thinking. By GPS loaded up with 200+ LB 2 guys she goes 36 MPH. Here's my plate.
y4mYcs3nLOelvJdTRUFtXK1IoUfb6nEciwOQRfabTTnrTwEKcmYyzlC428jYxkLCt8UMCjzRvpPoJrWGBTecRKeqyJPFaN3XYMyxLU3sdep5AwVo2FvJSjj9p_vY6LfFN4mOhg9la4wYTy8RS-4qyqsfOw3fSQ92osiwz_WJaWFsmFh0Ld9svLKlakDUYMR16WQZsvnevEStdfptfMIoqvU_g
y4mnGVW-Cz_hzWdjLY3agG2Js9Mmv9CtKZS6GweZGinKOSiMXIKyF9_-K2dLNJ2rkxGn1W0l7AVgaN3SFwHos1NnE0a1yiKHDSVFFuPoweVr1bJ9W2g1H2WYyWN63iw7zPkeGluDvwzkQghNC4bslrrbwDVQOPpltN0nQ6eJMOCHHeZklue6sPTqBWhWYijWOX4S3ClioP3456rSFGv3nga2A
y4m_EOOkFjRDWXctvv824LeTpqH-0foQcjimZpqkuqRCyUJ-Fhyn9gmmILfx90S5JY4pzHzQ5msezUC8r68O0YflTCcPj3JEaB9G3i3USThXrAAEYSSTvXm_zOAmE4sHmuRw3Vte5qppDoBdiK4CgvsevkqBkTtL5RhZCh6Id6jMOiZ9-O-3ZrbtfjjjGJgcQCnnHM884AWMDDDF3vsO_LczA
Watermann
I was thinking about using some fender washers to spread the force of the screw heads and sink them in where I have to already drill holes. Say in places like the splashwell tubes, motor mounts and using my transom saver too to bridge the gap for even more force.
I went out back at the lumber yard to get the ply, they said Ned was out there to load me up. As I drive around the corner, I see ole Ned tossing a sheet of ply on the concrete up against a truck. I about had a coronary after paying through the nose for that stuff. Got out to yell at him and turns out it was the junk ply they had top and bottom to loving sandwich my marine ply.
:laugh:
Thanks for the firsthand advice, the label says the bottle will do 16 sq feet but I was skeptical about that.
jasoutside
Just posting up so I can subscribe and follow along. She'll make a great fishing rig when you are all set with her - tons of deck space on this one!
I've never seen that version of glue before, very interesting:eagerness:
Pmccraney
Nice boat. I'd like to follow along as well.
Always good to sea another sea nymph project.
Watermann
End of the first weekend of the resto and I hit my goal, to have everything gutted. I do now officially have a hatred for black electrical tape. I know the rules say no bashing but I would like to bash in the guys noggin that cut the 2 round speaker holes in the little bulkhead. They had been covered up with some thin ply with carpet and I guess I saw them before but forgot all about it. I should look on the bright side, at least the guy didn't put in 10" subs.
y4mY43VW7fsTIEXN1ij6prHDIM7QLsnqa3cYnygIVByyYLX61TQxbF9Ho2z6QkbGemy8Lme2rgsRHE-g3hJvbT_ABHRpSmbWiDx3znq9Zu0eu5ktlVRuIx2KqOluKq1NUvCvVNKsmF_OoCDyjEvtxnEb8k7uA6TTmZ0P75nDPxPHOK1W44-3zAG4eAsIaofzZgCF6md8ESRhRT_0rQcvhrIaA
Some nice light, dry Styrofoam to bag up and toss is all that's left. Then the clean up begins on my next weekend so it will be slowing down on the progress.
Time to watch some football now and relax with a barley soda.
y4mN61Syszrv5L1RB0Rwcujq5ywFYG2dEO0E19yu8WSGgp56xpS2i4ug8SFcvPrRm3V8H32g66SZYacgdJXMpEbUbNYkqFV3T12W4xC8NCJR_23hpiwFjnBp48dQk7nxcWKQ26kyLvaOxWAfY2vuAxNljRbw4dA4DSRoLJpP0euvOPbPvPiTkWyZ1yyvnxt2Igjtr2LmPhbSr4ZUW7vJh-5yw
jigngrub
It's hard to tell from the pic, but is that an "I" beam keel stringer?
Watermann
I have a "what the?" for you guys in the know. This hole has been cleanly cut on each side of the hull in the same spot and then welded up with a plate from the outside.
y4mu1HzSKdTSAA-RQsbl6GASDhikp5gghjsR4SjufY61cOg9fAruBHQgB7qY7Wb81BLViXshsCWpx-8WGD8QOU05MtdHrtV3miNjuS30iNQlZOoKqkuHbUIjoWjpicLrpPRqncD7qVtoq2qMOXGFEG_F63LDDYXaMIjFFcV_uwhGGWcdpIhZxysJjWsUUDNDAZpkJhNMzWmsSJvi7GWO1MurA
and then a closer look.
y4mD1QiYJZR1n5GO034be1_Z4FJraI0V0ILjEvYjkVRWDoWpk0MvBQr_F81_1LnEHjwAqZpm0e6uKMnxPHdFmzWtUApTcgcPhy_HMu0F33-7ZpA-kFnFoHFP12kGLjCsTdsmdV2c0S1qkSq0_eiLZh3hRrNt9mSNkWHdr564kZZu9B9bbmsDfOY1i6aWaMiVVXROcDk5HCHIyKeoBLA45JeTA
and from the under belly, the welded on plate.
y4mh9gmYWGxkYTTJoJ77Mz2kbzix-0Tl_9g-tWmA1r8077yKY5JLv3_mRoXKCtR_5PNKteXBbO_N5niD7lQb0Amd61ryTTqO-vyexfqVNKAaM3dwXhU56Ut2I4C8TN3rrnp5JtKkaktlEAOu_sY4uvVSjD32vgv66zMEerA-ZiNd5J7SJdbjetsAuEtO3hY4EuvlQQtSJS-S6yVW2cO173YoQ
If you can't tell from the pics the holes are located about 2 feet from the stern. Any ideas why this was done?
Pmccraney
Very bizarre; To be honest, I have no idea. My only guess would be a trailering accident that punctured the hole in similar spots (which would explain the punctured look - facing to the inside) with the welded plates for the fix... Who knows?
jbcurt00
This pix makes it look like there was something mounted over/thru that hole because there appears to be 5-7 rivet/bolt holes around the edge of the 'tear'..
Odd for sure......
Pmccraney
Odd for sure......
Yeah, that was my first W.A.G., but the cuts didn't look clean enough (or round enough) for a thru-hull drain, pump or transducer... its weird the way the cuts were peeled back sort of lick a 1980s beer-can pop top...
