hello all, i have a merc 115 efi which i believe has the same power head as the yamaha f115. i am having some problems tracking down a overheating problem. can anyone tell me the route of the cooling water from pump to pee hole. i think i might have a problem where the water tube joins the power head but to check this i would have to remove the motor and go in from the top. i was wondering if it is safe to remove the lower unit and put a hose into the bottom of the water tube and then disconnect the the water pipe just before the stat and turn the hose on to see if i am getting a good flow. i am just worried about water going where it should not. sorry for the long post.thankyou
