Re: Is this to much motor?
There are "toons" and there are "toons." I've seen modern tri-toons that can handle that much weight/power and more. These are also boats that have strakes on the toons that make them plane more like a conventional hull. Most importantly, these boats are fully controllable at higher speeds.
Since your boat is much older, none of what I just mentioned is most likely the case. Whether the proposed 175 is too much for it, I don't know, but I would do a lot of homework, before I tried it. You might be able to do enough research to find out what your boat is rated for. You might also be able to find out how hp rating was determined for toons that are designed like yours and use the same materials. You might even contact the Coast Guard to find out how you should rate it, now that it is being considered a home made boat.
Let us kknow how you make out.
