Watermann
- Jan 12, 2013
- 13,753
Re: 1978 Sea Nymph SS160 resto
Yeah I was considering all of the above with the exception of when I do the flip, I will grind off all of the old JB on the outside and replace it with a nice smattering of marine tex. I plan on then sanding it down to a nice smooth shape that doesn't make it look like a humpback. I will also drill out the crack ends and fill the holes and pits with more marine tex. I have gluvit to top it all off on the inside keel repairs, seams and rivets. If any of those rivets keel are loose, I will use the Gflex on the outside as well.
I would love to be doing more but I get out and putter around cleaning and fixing for a couple hours, just to be on my feet every day and moving. I can't lift anything over 15 Lbs so my drill with a wire wheel fits the bill there. Having some very nice stable weather right now that's melting away all the ice and snow so being outside isn't so bad.
If possible would like to see pic of same area on outside. Wondering how bad the keel has deteriorated. Might help everyone.
For kicks did an advanced search on "cracked aluminum keel" and quite a few hits, suggestions, repairs.
Obvously can drill and stop the crack but from there it will be very interesting to see what suggestions come out.
You could shape a piece of 5052H32 alum. to fit into the area. Some combo of gluvit, gflex, 5200 would come into play between the patch and keel. Fastening it might be straight forward if you hit the flanges of the keel on outside ??? May want to make that piece a bit on loose side along edges....not sure on that part. The epoxy / 5200 would seal the gap.
I'll be following with interest.
Have you had your surgery and still doing all this stuff, let alone working outside ?
