'zuki df 140 fuel issue
AK-JAY
Had my boat out on the water this weekend and the the rpms started to drop off. Was running at about 5400 and ended up at about 3800. Checked the racor filter bowl and sure enough full of water. So i got to the fuel dock and pumped the remaining fuel (using the primer bulb) into a barrel and put fresh fuel in and changed out the racor. Ran a little bit better but for about 3 min and then the rpms started to drop again. So i changed out the racor for a second time and hooked my fuel line to a small boat can that i know had clean fuel in it and still had the same problem. I draind out the fuel injector rail and the high pressure fuel pump and the fuel looked good...no water but i still cant get the rpms up. so now I'm thinking its that the high pressure fuel filter is clogged from too much water and is limiting the flow of fuel. I have orderd a replacement. what do you guys think? Am i on the right track? I live i remote area of alaska so taking it to the shop is pretty much out of the question.
Thanks
Jay
99yam40
Re: 'zuki df 140 fuel issue
Yes, sounds like the right direction.
I would not think you can remove all of the water out of the tank by using the primer bulb, may need to pull tank or at least open up and suck all fuel out and then mop up the last bit of water with rags.
You need to check to see how many filters and screens you have in the system and clean/replace them. Maybe the injectors also, they have screens too
