zodiac serie 1 s131
rudedog
Does anyone know the order to put the flooring in. When I put it together, it is about an inch too long for the boat. There doesn't seem to be enough give or room lengthwise. Help!
deejaycee_2000
Re: zodiac serie 1 s131
welcome to iboats ..... You need to inflate the boat slightly and then pop in the floorboard, stat in the front and work your way to the back .....
nobrainsd
Here are the instructions for a Futura. I don't follow the directions to use the oars under the boat. The real trick is getting the two floor sections to "tent" up and then stand on the peak. Hope this applies to your serie 1.
