- Oct 19, 2017
- 18
Year !
I started detaching the PVC patches around the transom. Due to heat and traction, they have gained ripples and have elongated. I would like to use them as a template and use a PVC (strongan ) for new ones. The most sensitive part seems to be the one at the joining of the transom with pontoons, that is, the strip that stick the pontoons on the transom at an approximate 90 degrees angle. I'm afraid it'll make creases when reglued .
What do you think about this soldering area? Should I cut some "V" as in the photo? Thank you !
