Re: Z150 TXRB running poorly
As I mentioned when I pulled the vacuum hose from the regulator the fuel pressure gauge did not budge. I pulled the regulator and the little screen filter was ~30-40% clogged. (This engine has no shortage of filters!) The regulator also seems to be seized up. Any suggestions to test it further off the engine?
I may replace it at ~170$ and run the engine again before pulling the hp pump.
