Re: Ymaha 50 (95 model) misses
Remove and rebuild the fuel pump. I'm not familiar with your engine, but the fuel pump may be integrated into the carb, or a stand-alone device. Checck the engine's compression ,as fuel pumps use engine vaccumm to operate them,and also<br />to draw fuel into the engine.<br />Check with hand on the head for heat differences,to determine which cylinder is not getting fuel. If you find one cooler than the other, and you only have one carb, you should suspect an ignition problem instead.
