Yikes rusty spark plugs!
cprodave
Now that I got the jammed cover off my recently-purchased 1998 8hp E8RECR Evinrude I think it would be best to replace these Autolite 425 plugs. Outboard starts and runs fine but plugs are heavily rusted outside surface--worst I have ever owned, or possibly seen on a functioning outboard engine.
Cross-reference chart i am using does not cross to any Champion plug that I see on the BRP/OMC exploded diagrams. What Champion marinized plug matches Autolite 425 (heat range 5 or possibly 1 hotter = 6)? Thanks...
​https://www.sparkplug-crossreference.com/convert/AUTOLITE/425
MTboatguy
Actually the OEM plug in my book is listed as the Champion QL86C if you can't find that one there is several equivalent plugs available.
cprodave
Lo and behold I looked inside the cowl and (amongst the cobwebs) I found that a previous owner made note of the QL86C sparkplug ( same as I see listed first/standard in the BRP/OMC exploded diagram). Thanks MTboatguy for confirming what is standard.
