H2ot Times
- May 11, 2008
- 21
Should I be able to grab the outdrive,with the boat on the trailer, and lift it up with no resistance ?
1979 3.0L OMC400. I took the cover off of the tilt clutch and found milkshakeWhen I lift the outdrive the outer ring of the clutch doesn't turn just the inner part does The tilt motor doesn't work at all, but I think that is an electrical issue.
I have already had it in the water and did slight damage to the ball gears when I tried to use reverse and the outdrive tilted up rather than the boat backing up.
