Year of my Mariner 90
Morfy
Hi all,
I have a Mariner 90 it seems to be a 1985 model, but not sure. Serial number is:6625062. Does any one know the year?? and would it be 90 at the prop or at the fly wheel??
Thanks
achris
More fish than mountain goat
Re: Year of my Mariner 90
Hi all,
Thanks
Yep, 1985. 90hp at the crankshaft, somewhat less at the prop.
Chris.............
Morfy
Thanks mate,
10% to 15% less at the prop Im told. Its a great motor and never had a problem. Although mates of mine recon to use it as an anchor and upgrade to a newer 90
achris
About right. Tell your mates they're idiots who are talking out of their collective be-hinds! Tell them you'll upgrade, if they pay for it... :D:D As far as that 90 goes, it's way lighter than a new one, by about 30lbs....
The old inline 6 is still my favourite engine. Easy as to work on and reliable. A little noisy, but oh, what a noise. :D
Chris........
Morfy
I agree mate, Parts are easy to come by and reasonably cheap. just on another tack, the pitock tube from the leg of the motor to the speedo i have replaced but the speedo does not work still. Im assuming that I need another speedo, possibly an after market one.
achris
Take the tube off the engine and give it a good puff. If the speedo moves, then check/clear the blockage in the pickup. If the speedo doesn't move and the air is not escaping through a hole in the tube somewhere, replace the speedo. Any aftermarket will do. Pressure in the tube is pressure in the tube, doesn't matter about length or diameter....
Personally, I don't use pitot speedos any more. GPS is waaaay more accurate... Especially at low speeds.
Chris.......
