Re: year and size of motor
301848 is a part number that is cast into some part on your engine, and the year cannot be identified from it. Fastwins are 15hp (early '50s) to 18hp ('70s or later?). <br />We need the model number to properly identify your engine. It is normally located on the nameplate on the transom clamp. If this is missing, you might find it stamped into the welsh plug on the engine block. It is a quarter sized silver disk, similair to a freeze plug.<br />Your model number probably looks something like 18zzz or 15zzz. 3zzzzz numbers are part numbers.<br />Good luck!<br />(Edit - Cripes! X X X is a problem? I'll use Zs instead. Sheesh..)
