Yamaha Waverunner III (650cc 1992)
PJDK9020
I am rebuilding the jet unit on my 1992 650 Waverunner III.
Can anyone assist me in the re-assembly sequence of the jet unit? i.e., do I press the bearings onto the shaft and then press the shaft and bearing into the duct impeller or what order do I do this?
hall832
Re: Yamaha Waverunner III (650cc 1992)
Model and serial?
hall832
Is it the WB650U
hall832
1. install oil seal
2. install
bearing(front)
drive shaft bearing
3.Fill Between shaft and the duct (grease)
4. install rear bearing
5 Fill into the cap(grease)
6. Install impeller
hall832
Just a heads up, there are allot of forums dedicated to Yamaha skis.
PJDK9020
Thanks very much. Don't have the model/serial available at the moment (I am at work) but the sequence makes sense. I "press" the front bearing in then "press" the shaft onto that then "press" the back bearing in and then install the new impeller.
I'll let ya know how it turns out.
hall832
do not forget to pack it full of grease
