yamaha tach reading 7000rpms at idle
ctrahan18
i have a 200 yamaha the tach was working fine last time i went out i went out and started the boat today and its reading 7000 rpms at idle and its idleing normal i checked the green wire from the tach to the stator and everything is fine :confused:
Silvertip
Honorary Supreme Mariner
Re: yamaha tach reading 7000rpms at idle
On the back of the tach is a calibration dial. Note the current setting. Then turn that dial back and forth (GENTLY) several times. Then set it back to the original position. Sometimes that adjustment gets a little corroded and turning it back and forth cleans the connection and the tach works normally again.
