ebbtide954
- Jan 22, 2014
- 7
I've recently acquired a 91 ebbtide with a 350 and yamaha stern drive. From what I've researched the drive is almost as good as the anchor that came with the boat. I would like to make it work and make it reliable as possible though. I finally got the boat fired after chasing wiring and fixing the timing and firing order.. also carb adjustments. It is hammered knocking and squealing like crazy. So I will be pulling it and installing a new short block. First question is how much power can this unit handle hp wise. Second, what if anything can I do to make it handle hp better. Third, what problem parts do I need to look for when I get the motor out.etc etc. This is my first boat I have owned. I'm rather knowledgeable on cars and motors. I've installed a couple motors in baja's with merc outdrives at the performance shop i used to work at but any advice would be greatly appreciated. I will probably ask a bunch more dumb questions in the future so sorry in advance.
