Spunbearing
Thread starter- Joined
- Jul 18, 2010
- 4
I'm new here and stuck on a '97 yamaha 150 saltwater series. Having trouble with the trim and tilt, had a friend of mine helping me load the boat tilt the motor all the way up and was not able to tilt back down after that, pump motor would run both ways, so I checked the fluid and it was full. Pulled the unit out and put it on the bench and couldn't get it to go down, sounded like pump not building any pressure going down but had pressure going up. Tore the whole unit apart, pump itself, pistons out etc. Not able find anything like a stuck check valve or something along those lines. I reassembled the unit (quite fun) and cannot seem to get the air out of it. Have run out of ideas. Any ideas on why the piston stuck in the full up position in the first place and are there any tricks to getting the air out of the system. Thanks.
