Re: Yamaha hard steer,again
If its hard to steer to the left, move the trailing edge of the torque tab to the right (it steers easily to the right, correct?) It's definitely from the torque of the prop...been there done that. You will see marks on the bottom of the torque tab and you can experiment until you find the right spot. Dont be afraid to go to the last line if necessary. Also, before you tighten that tab for the final time I would put some loctite on the mounting bolt as they can loosen up pretty easily.
