Yamaha fuel management and fuel guage
slorebo
Hello all,<br /><br />My Mako 224 with a 2000 Yamaha 225 OX66 did not come with a Yamaha fuel management guage, I would like to install one. Not having one now how involved is it and will my existing Yamaha wiring harness work?<br /><br />Second question is on the Yamaha speed there is i fuel guage that is not wired into my tanks sending unit, what is involved in getting the Yamaha fuel guage to work on this?<br /><br />thanks!!!
rodbolt
Re: Yamaha fuel management and fuel guage
its all plug and play, buy or borrow a copy of the rigging guide and follow the instructions, on the fuel guage it depends on the fuel sender in the tank.if the sender is a US standard,yamaha standard or European standard and it works all you have to do is set the dip switches in the speedometer correctly.<br />the FMM will come with a sender and a harness if you buy the kit, make sure the white/red wire is taped/sealed off and does not get wet.<br /> the rigging guide has instructions on how to hook the speedo to the FMM and how to plug each wire in.
slorebo
rod,<br /><br />FMM=Fuel Management Meter?
rodbolt
yes<br />FMM=fuel mamagement meter.
