FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Hi,
I have idle problem on my F115, RPM (800,900) at neutral.
I would like to adjust TPS but I don't know voltage I have to read ?
As I saw in another post, it seems to be between pink and red wires ?
Many thanks
OK, many thanks, sorry I made a mistake there is only 3 wires (black, pink, orange) and you are right, it is between pink and black but it is very difficult to adjust, very sensitive. I done the job, when started engine, idle was at 800/900 RPM but when hot, and started it again, idle remains normal (600/700 RPM).
Many thanks
This spring my F115 would idle (in neutral) at 7-900 with a slight fluctuation regardless of whether it was cold or warm and not at 600.
After advice from Rodbolt and others, we found it was the thermostat. It was not closing completely. Pull yours and test it. It should be changed every 2-3 years.
