Yamaha F115 Key ignition switch or wiring problem?
Trey B
After turning the battery switch on (checked - strong battery), placing the gear shift lever in neutral, attaching lock plate to the engine stop switch, inserting the key and turning it to "on", I get nothing. The digital gauges are not powered. Other eletrically powered devices on the boat work with the exception of the trim located on the gear shift lever. Any troubleshooting ideas? Can I bypass and start the engine?
Trey B
99yam40
Re: Yamaha F115 Key ignition switch or wiring problem?
Trouble shoot with a voltmeter to see where you are loosing the 12 volts at.
Big flop
Did you check the fuses
on the motor, under the
motor cover??
