Superjetjim
Thread starter- Joined
- Jun 5, 2010
- 246
2003 Yamaha F115 outboard 347hrs
My outboard recently refused to start, I assumed VST filter or low pressure filters had blocked, I've stripped and cleaned them all, drained the tank and added fresh gas - still the same. Quick blaster of starter fluid and off she goes for a few seconds but then stops.
Identified down to fuel supply and the high pressure rail had no pressure. I then connected a 12v feed directly to the fuel pump in the VST (unplugged the lead and connected to the pins with crocodile clips and connected a small 12v battery I had) pump spun up and she started instantly. Looks like I've found my issue - question is how to I find out why I have no power to the fuel up pump? What do I need to swap out to fix this, a relay somewhere?
Thanks,
James
Thanks,
James
