Yamaha f100 problem
5kjeff
I have a yamaha f100 i rebuilt the carbs sync them, it will start and idle fine.
It stales when i trie to accelerate.
Can any buddy help.
Jeff
jay_merrill
Re: Yamaha f100 problem
Your in the wrong place, buddy. I've sent a message to the mods asking for this to be moved over to the Yamaha forum. Those guys will help, I'm sure.
99yam40
Can any buddy help.
Jeff
1st thing is to turn on your spell check:facepalm:
Next give a little more info/history on the motor.
When was the last time it ran well?
Have you checked to make sure the cylinders are sealing properly(leak down test)?
what all has been done to it?
Did you follow the service manual and sync with the 4 channel manometer?
How did you sync your carbs, I hope you did not soak them:facepalm: 4 stroke carbs are kinda tricky, it would not leave the shop until I balance the throttle plates with a carb tuner.
5kjeff
hay commander wasn't looking for a spelling lesson, don't sound like you know what your talking about
99yam40
A motor needs several things to run properly and provide power once put into gear and loaded up.
Good compression
Good spark at the right time
the right fuel air mix into the cylinders
looking at your other posts on this motor, which we should not have to do to see what all has been happening on the motor, either you did not clean the carbs and the rest of the fuel system including tank and lines properly or you did not get a service manual and sync the carbs with the proper equipment like recommended
If you do not have spell check or do not know how to use it, or just refuse to use it ,I guess we will have to live with the results.
looks like a good education is not what it used to be. Of course the students have to want to learn before they can be taught.
Not sure what our school tax dollars are being spent on beside new buildings, seems like there is a lot of I just don not care now a days
