FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
no "kits" avalible. tear it down carefully inspect the crank,rods and bearings. I always replace the bottom bearing but the rest are ok to reuse if not damaged.
inspect the rods.
bore the cylinders and replace the piston assy's.
use new gaskets carefully inspect or replace the exhaust divider plate.
inspect the shift shaft for rust while the power head is off.
Thanks man, I could not get it to idle rite, pulled the plugs,found water on # 3 ,coming from inner exhaust gasket, just starting to score #3, going to install new pistons & bearings
