John from Madison CT
- Oct 14, 2001
- 176
Hello,<br /><br /> I have an 1990 Yamaha 90HP outboard. I wish to drop the lower unit and change the water pump. I am able to get all the bolts off BUT, I do not know what to do next.<br /> I have the aftermarket manual made by Selco, and it says that you need to disconnect the shift rod. First you put it in reverse then you undo a nut, just above the lower unit section, that holds the shift shaft connected to the shaft near the midsection of the whole leg.<br /> When you look at that part of the shift shaft, there is NO nut to disconnect, you only see shaft going into this mid section of the lower unit.<br /> Gee I hope that makes some sense. <br /><br />Has anyone hear done the water pump on a 3 cylinder Yamaha outboard and can offer some help?<br /><br />Thanks guys,<br /><br />John from Madison, CT
