aussie_mike2
- Jan 19, 2010
- 8
Yamaha 90 Petrol 6H1 Two stroke Runs but is missing on cylinder 3 and stalls
Hi Guys , been searching the net for some information and come across this forum.
Would appreciate and input/help with a problem that has shown its ugly head.
My boat has a Yamaha 90A Petrol 6H1 Two stroke carbureted which is a 90Hp 3 cylinder motor.
Last trip out in Port Philip Bay I noticed the motor was down on power and using more fuel than what it usually would use on a similar trip out in the bay.
I noticed the motor is running rough and stalls , so back at home I started investigating and found that spark plug in cylinder number three is not firing. The plug is extremely wet with fuel. I replaced spark plug in cylinder number one with spark plug in cylinder number three and the problem still remained in cylinder number three. So it is not a spark plug problem.
I did a manual cylinder compression test and all three cylinders had 110PSI compression in them. So there is no mechanical problem in cylinder number three.
Then I swapped lead/coil number one with cylinder number three to see if it is a lead/coil problem , still the problem was in cylinder number three.
So now I have established its a ignition electrical fault of some sort.
I have no manual nor do I know how this electrical system works. Nor do I know what the electrical system consists of to run the ignition side of things on this Yamaha 90 Petrol 6H1 Two stroke.
I am very familiar how a automotive electrical system works on a breaker points system (Kettering Ignition) , mechanical electronics ignition system and ECU system but marine outboard motor ignition systems are not my strong point.
Q1. What generates a electrical pulse for each cylinder?
Q2. What controls the ignition timing on the motor?
Q3. Does anyone know of a manual for Yamaha 90 Petrol 6H1 Two stroke engine with ignition electrical details on the web. I have done a few searches but very limited information?
Q4. Where is a good source to purchase the parts for this Yamaha 90Hp motor overseas or Australia at a realistic prices once I have established what I need to purchase?
I have also done a search on this forum and found people with some form of no start issues with their engines and read the threads. Which I will be searching the archives in this forum in the meantime and doing some more reading.
Any help/input would be appreciated to solve my problem.
Cheers
Cheers
