maineiac5586
Master Chief Petty Officer
- Feb 14, 2009
- 818
I have a 2008 yamaha 9.9 2 stroke. Starts intermittently and when it does it starts off running fine and then it shuts off. Electrical is good. Compression 130 both cylinders. Carb has been cleaned and all adjustments set. I took it to a marine mechanic and he thinks it is leaking internally on the intake side of the powerhead. He said fuel is not getting pulled into the crankcase due to pressure loss in the powerhead. He said engine can be fine on the cylinder head side but lose compression inside. This engine is super clean and worth fixing. The mechanic changed the powerhead base gasket, the exhaust cover gasket and the head gasket.
before I pull this apart is it possible the seal that goes from the carb to the intake manifold is not sealing and creating an air leak? It uses a super thin o ring for a seal.
