2shallow2sail
Thread starter- Joined
- Jul 28, 2008
- 30
I got this motor last year, I have done a bit of work but am still having an issue with top end power. When I have the motor on the muffs/bucket it starts on one pull and idles perfect. Once in the water on the zodiac, the motor will run fine as i throttle up to WOT and then after around 20 seconds running perfect up on plane, the motor starts surging/bogging (apologies I am not sure of the proper term). The motor will momentarily lose most of its power very abruptly and then suddenly regain that power. This causes a lot of head jerking for the driver and gets worse the longer you try to run above 3/4 throttle. Once I throttle down to idle and wait a minute, I can throttle back up to WOT for another 20 seconds before the symptoms repeat. The symptoms do not seem to improve if i pump the ball on the fuel line while running.
This weekend i rebuilt the carb and it idles even better than it did and is smooth to power up to 3/4 throttle, but still has the same surging and loss of power issues on the top end. I have fresh fuel, and brand new fuel hoses from a 1 yr old 6 gallon portable tank. The motor pumps water fine and does not run hot (new t-stat and water pump last year).
Does anyone have an idea? I believe that it is getting either too little or too much fuel. Will adjusting the needle screw on the carb allow more gas to flow? Or is the needle screw just for Idling. Also thinking it could be the fuel pump, but thought that pumping the bulb underway would help if that was the culprit. Could it be electrical or timing issues?
Sorry for the long winded post, I did a lot of forum reading before posting so I wanted to make sure I gave all the info I had. Many thanks.
