Hi everyone hope you can help,
I have a Yamah 40 (not sure of exact age but I think is about 20 years old)
The problem is the engine starts OK, when the choke is out out but when the choke i pushed in engine stalls (most of the time but not eveytime), when it does not stall and you go into gear it normally stalls after a couple of mins but you do get drive and go forward before stalling.
Also the engine races sometimes when the throttle is set to low before stalling, sounds like a fuel issue to me but can anyone tell me, .
a) the corret mix 100:1, 50:1 etc etc (we are currently on 50:1)
b) any idea what could be wrong, it's getting emabarrsing leaving the bearth just to be seen wading the boat back in a few minutes later
tonight i am going to start checking through,
I presume the order fuel gets to engine is
1) fuel tank
2) fuel filter
3) fuel pump
4) carb
thanks in advance,any help greatly appreiated.
1) fuel tank
2) fuel filter
3) fuel pump
4) carb
