yamaha 30 precision blend
kennywain
here is my issues it has been stored for 2 winters in minnesota. I had the carbs rebuilt in 08. it still didnt work great, but it did work, couldnt get to plane down without passenger in front of boat. problem now is bluish smoke after gunning the ingine to keep it going, it feels to me like it is starving for gas then i rev it and i get the smoke. I can keep the choke pulled and it will stay running then i shut it off and it takes off just fine for a couple of seconds. then its back to bogging like its starving and some smoke?????I pull choke and it revs again I turn it off the motor takes off for a couple of seconds then back to square one. Anyone??? Any ideas???
Re: yamaha 30 precision blend
Sounds like fuel delivery issue maybe carbs again have you run stabilizer in your gas?
99yam40
If the choke helps then you have fuel in bowls, so I would have to say the carbs need cleaning as the passages are plugged
