yamaha 225 OSX fuel problem ? bogging down @ 4000rpm
don / fenwick
MY Yamaha 225 salt water series continues to bog down after 10 min at 4000 rpm. i replaced the high pressure fuel pump and all screens/ filters are new or clean .
N1NE1
Check to make sure the oil tank on the side of the motor is keeping up and staying full.. Could be a clogged oil filter off of the oil tank.Motor will go into limp mode if tank isn't filling
99yam40
look at gauges to see if they tell you anything while this happens and test your buzzer to make sure it works
