yamaha 200hp 2stroke torque steering
ddzurik
I have a 96 Grady White 268 with twin 200hp Yamaha salt water series 200txrt motors.
I took off both lower units to have them resealed in the fall and am now putting them
back on. I did not mark the location of the anode on the cavitation plate above the
props. One is a left hand motor and the other a right. What position should I mount the
anodes in order to correct any torque steer from the motor.? Thanks Dave
noelm
Re: yamaha 200hp 2stroke torque steering
we need to know how the steering behaves now, you adjust them so the steering is neutral, so some trial and error is needed, remember though, when you adjust the tabs, you adjust them to steer the MOTOR, not the boat, just sit down and think about it for a bit before you adjust them.
