Yamaha 200 HPDI / Stamas
wesjones
I recently purchased a 2000 27' Stamas Tarpon with Twin yamaha 200 HPDI's of the same vintage. Everything is in great shape and the motors run very smoothly. On my run down from the dealer to my marina i notice that the motors top out at 4800 burried, maybe 5100 with a little trim up, however you can hear the props cavitating then. My marina says the motors should top out at about 5600 and may be propped wrong.
Any ideas?
Thanks,
wes
99yam40
Re: Yamaha 200 HPDI / Stamas
could be propped wrong or motor problems.
motors need to be able to hit high end of WOT RPMs with the load you are running that day
chapin123
I recently also bought a 2000 25 Stamas with twin Yamaha 150 HPDI. I had the same problem and i replaced the fuel filters. Also i just bought the racor filters with bowl to help with cleaning gas. Still after i change filters the starboard engine felt wrong at high RPM,so we took out the fuel injectors and cleaned them. Now the engines are working perfect.
I hope this helps!
Merry Christmas!!
