Re: yamaha 20 hp
could be either one, usually you can pull that carb and clean it out and reassemble it without much problem unless the rubber bowl gasket swells.<br /> the lift pumps we just replace as a maint function, it could also be an airleak on the suction side of the pump to the liquid level in the tank, occasionally the quick connects on both sides of the fuel line go bad or the filter on the motor may be missing its gasket. sounds like for whatever reason the fuel bowl is running dry.<br />the lift pump is rebuildable if you wish but the parts cost almost as much as a new pump, or at least in the US. if you have a vacum guage you can install it at the suction side, vacum should be about 1-2"Hg. pressure on the outlet side should be 3-7 PSI.
