yamaha 2 stroke 50 honda bf50 4 stroke
skoskii
Hi,
I need help deciding which engine to put on my futura mark 3.
i like the yamaha for power and low weight.
but the honda will be quieter burn cleaner and run more efficiently. but will cost me around $1000 more.
What you do think?
thanks,
JB
Re: yamaha 2 stroke 50 honda bf50 4 stroke
Sooner or later you will run into a sign that says, "Carbureted 2 stroke outboards prohibited".
steelespike
As far as banned 2 strokes I guess that depends on where you boat.
The Honda is a fine motor and might deliver ever so slightly better fuel use.
It will easily use up the difference in routine maintainance intervals.
The 4 stroke generally will require more careful setup to have the same or close to the same hole shot.I think the most important thing is to have a well established
servicing dealer close by.
