Yamaha 15hp enduro parts
gwozhog
I have a recently aquired a 2006 yamaha 15hp enduro 2stroke. I understand they were only sold in the carribean. Does anyone know who has parts available. I cant find any websites or any information. Sure someone in the USA is stocking parts for this engine. any help would be aprreciated.
Sea Rider
Mod EDIT: please PM that site to gwozhog
​Happy Boating
tommarvin
Ensign
What parts do you need, this site iboats.com sells some Yamaha parts.Where do you live ?
You could always go to the Yamaha dealer for parts, you can't get anywhere else,like on e-bay, amazon, google search,type in the box, 2006 Yamaha 15hp endure 2-stroke.
gwozhog
I wish it was that easy. I have even clicked the link listed on where to buy endure parts. I have found absolutely no information on a 2005 endure 15hp. I have combed the world wide web thouroughly. Parts are different than the leisure model because the engine weighs 6 pounds more. It would be nice if someone had a link to an exploided view of the engine listing part numbers but I have not been able to find that either. combing other forums and youtube the only thing I have gathered is that parts must be ordered from a dealer who sells them in the carribean or overseas. I do not need any parts currently but I like to plan ahead. Summer will be hear before we know it and I always like to be prepared. If someone could please chime in who owns 15hp endure 2stroke I would appreciate it.
tommarvin
Ensign
Check with the dealers in the Caribbean and overseas, for a parts catalog, and users manual" were all one love here",you can get anything in a day.
We think alike, what if something breaks, I already know which machine shop I'm using when something breaks inside the motor, how sick is that.
Whenever you buy a used motor you want to change the water pump/rubber impeller, drain and fill lower unit with 100% marine gear lube, it's tested with 10% water contamination, and it still easily passes. Put the thermostat in a pan of cold water heat it up slowly what temp does it open? Change all on engine fuel filter,add a 10 micron spin on water separating filter 6 bucks,pour it out at the end of boating season light it on fire to burn it up grease the rubber gasket spin it back on. grease all grease fittings, drain the carb bowls float switchs ok, put the largest drill bit in the idle jet to gently clean it out
tommarvin
Ensign
Contact Yamaha headquarters and ask them, tell them you need help, they will help you and give you a contact person.
I saw a sticky, Iboats has enduro parts click on Yamaha outboard motor parts.
gwozhog
Well the 2 stroke gods favored me this month. I sold the enduro and got my hands on a 2010 15hp yamaha 2 stroke leisure model with less than 10 hours on it. I think it was the last 2 stroke sold here in the USA😃. I just could not stand the idea of not being able to run down to the local yamaha dealer for future problems for parts or service work. Im sure you could call a carribean dealer for parts but i much prefer to not hassle with it.Problem solved anyways. See ya on the water.
