yamaha 05 175hp HPDI - Where does clear tubing go?
modicon2
Greetings,
I've got a 2005 Yamaha 175hp HPDI. There is a ~1/4" clear tubing that come straight off the top of motor (compression nut) that appears to route down engine and go into the bundle of wire/cables that come out front of motor (big flex hose covering) across splash well and into hull.
The tubing had a split in it right above the compression nut and was shooting water out. I was able to temporary fix it on the lake by cutting a small section off and reconnecting it. I'm consider replacing hose and redoing the compression nut fitting.
What is this tubing for? Where does it go?
Thanks!
mike_i
Are you able to trace out the entire length of the tube? Do you have a water pressure gauge on the dash, if so is it working?
modicon2
It does go to the water pressure gauge in dash. Thanks!
