Y pipe removal and block off
krisnowicki
I stopped my repower project today after a lot of progess but the ypipe bolts wont budge. Do I need a special tool to do these, I am having a hard time getting a socket to grab it the bolt heads have ridges on them... Any one know a trick to this. I would imagine I could just hammer a socket on it but I don't want to break anything.
Bt Doctur
Re: Y pipe removal and block off
Try using the correct socket, called a 12 point ,bolt size is 3/8th
45Auto
12 point 3/8 socket is what fits them if they're not corroded.
krisnowicki
mine is way corroded. I tried a 12pt 3/8 and no go.... oh well... I will try hammering a socket on...
Don S
Try a 7/16" 12 point socket before you start hammering.
Bt Doctur
SS bolts don`t usually get a lot of corrosion?
