jze1212
- Feb 11, 2006
- 156
I recently picked up a 24' aft cab Invader, with a Mercruiser 5.7 I/O. I bought it with the assumption that I may have to replace the engine. But I'd like to see if I can get this one going. The engine looks like it has a new starter but it turns over slowly, as if the starter were geared wrong, like a creeper gear.. Strange. Sounds the same with spark plugs in or out. Sounds like the starter is working hard and cranking over yet the motor is not turning over fast. I am going to pull the starter and put a good one in, not til next week.. I thought I would ask anyone if they have come across this? The battery has a full charge. I did a compression test, only on the left bank of cylinders so far, compression is low across the board but fairly even. I am not convinced those results are accurate though based on how slow the engine turns over, and I heard that the lifters may not be pressurized due to sitting around. Is it also possible that it could be a starter for a left rotation engine?
