Wounded Warrior new to boating. Evinrude E115TLCO, where to start
srfobx03
I'm not sure if this is the right place to post this. I have recently had a boat with an Evinrude 115 VRO V4 (I believe it is a 1985 Model) donated to me. I was told it hasn't been run in about 2 years. I am not sure where to start to get it "tuned up" to get it running. Any advice would be greatly appreciated.
Oh the outboard model number is E115TLCO I think.
Honorary Supreme Mariner
Start with a compression test.--Then check for spark that must jump a gap of 7/16" on each lead.--Determine whether the VRO is still in service and run with 50:1 fuel in the tank untill you check out if VRO is working or not.------If those test good then you might want to inspect / clean the carburetors.-----Then try and see if it starts.---Then look into installing a new impeller and changing the gear oil.---
srfobx03
Umm.. ok. Guess I have some research to do. I have no clue how to do a compression test. I am trying to save some cash and work on it myself. How do I test the VRO? And for spark, you mean the plug gap correct?
gm280
If you name indicates that you are a wounded warrior, I want to thank you for your service. I appreciate it indeed sir! :usa2:
No , the sparkplug gap is only about 0.030" or 1/32 of an inch.------But the ignition system was designed / engineered and built to be able to jump a gap of up to 1/2" and that is the proper test of the system !
srfobx03
Oh I see, so put the plug into the plug wire and the other end against the block or something and see if it sparks right?
emdsapmgr
You can also do another easy spark test. When cranking the engine, put an inductive timing light on each plugwire. When they fire, you will see the flashes from the timing gun. It will show misfires, no fires, weak firing and intermittents. If you have no history on the engine, regarding the water pump (impeller)- you may want to just change it straight away. No need to get an overheat on your maiden voyage. If you plan to do your own maintenance, there are two good things that will be useful to you. The factory exploded parts diagrams are online: epc.brp.com. Also, you can get an original factory service manual from the original publisher: outboardbooks.com
srfobx03
Yeah, I read about replacing the impeller. Thank you for all the advice and tips.
boobie
Best thing you can do is get an OMC factory service manual, read it and then work on it.
jakedaawg
If it has only been a couple of years since it ran it won't hurt to try and start it. Put a couple squirts of fogging oil in each cylinder and rotate the flywheel clockwise a few times with the plugs out. Put new plugs in. Clean out the fuel tank and line. Put a couple of gallons of 50:1 premix in the tank. Check the lower unit to make sure its full of lube. Fill up a trarsh can with water. Make sure the engine is in the water a few inches over the cavitation plate. Clean the battery cable ends with a wire brush. Clean the battery terminals with a wire brush. Tighten the cables with a wrench. Install the safety lanyard if equipped. Squeeze the bulb until you can hear fuel going in and it gets firm. Try to start it. Push the key in while cranking until it coughs then raise the fast idle lever a couple of inches and crank again. It just may run. If it runs post back.
SparkieBoat
you can also search youtube for some very helpful videos on how to do compression and spark test and replace water pump impeller most all outboards are about the same on these things. I use muffs for water supply but a trash can will do.
srfobx03
That sounds like a great plan. Thank you. I'll post back on the results.
fishdady
Second boobie's post. Being a novice myself, the best thing I've done is get a Johnnie/Rude service manual for my engines. Get a service manual for your engine.
srfobx03
Ok, so new plugs, fresh fuel (50:1), new fuel line in. Fresh lower gear oil. The motor will crank, but not turn all the way over. It acts like it wants to when I pull up on the cold start lever but right before it cranks over the starter drops down/disengages. I also have fuel dripping down from behind that plastic cover that covers the carbs. I did not replace the plug wires yet, the didn't have them in stock. Any suggestions/ideas??? Thank you in advance for y'alls advice.
Bosunsmate
Is your primer bulb holding firm with engine off?
Post a video so we can see your starters cranking speed and your starting procedure
vasy
Get a rebuild kit for your carbs. There is either junk inside or a needle is warn out and letting gas through when it is not suppose to.
I saw kits on ebay for $10-$15, and the job itself is relatively easy. Can find a few YouTube videos on how to.
jakedaawg
Okay, now you need to have your battery load tested. Free at many parts stores. Also clean the terminal ends and battery terminals with a wire brush. Follow battery cables to solenoid and engine ground. Tighten with a wrench. Wing nuts and fingers are not acceptable. If the motor does not spin freely then we will need to inspect battery cables and do a resistance check with an ohm meter. It is possible that after cleaning and tightening the cable ends that there is still too much corrosion in the wires to efficiently cunduct the amperage needed.
While you are at the parts store getting your battery tested inquire about renting a compression gauge. Take one of the spark plugs with you so you get the correct fitting for the guage. I own my own and have never tried to rent one but taking the plug with you wont hurt.
If the above allows the engine to crank over fast do a compression test while your there. Only takes a minnow.
The leaking fuel indicates needle and seat problem. There are many posts on here about how to clean your carbs. You may not even need to buy a "carb kit". just clean and try first. You may end up needing a needle and seat, possibly a float due to the leaking fuel.
Post back after cable cleaning and what not. Plus wether or not you did the compression test.
jakedaawg
Oops, just Re-read the thread. If you already did all the cable cleaning just have the battery load tested. 12 volts on a meter tells you nothing, we need a load test. If battery passes load test lets check cable resistance. Post back and someone will tell you how to isolate cables and check for resistance.
We do not need to worry about casrbs until we get the motor to spin.
srfobx03
Awesome. Thanks everyone. Gonna try and knock out some of that tomorrow. The motor did spin pretty fast while cranking it today.
