Would appreciate some insight on winterizing the volvo duo prop - never seen this
spencerkechi
Most of my experience is winterizing Mercruiser lower units. The only other Volvo I ever owned until now was an old 1985 Bayliner and it was drained the same way you drain a Mercruiser. So, we just bought this 2000 deck boat with a 5.7 GSI and the DP. I was surprised to not see any drain plugs on it. Typically I drain the lower unit every season and put in new grease. How is this done? I appreciate your information. I think this is a wonderful site for boat lovers like myself!
Fishhead-1
Welcome to duo props, take both prop sets off and you'll see the drain plug in there. You'll have sm-dp Drain manifolds, drain block if you don't have fresh water cooling. You will want to pull drive and grease drive shafts and prop shafts check alignment etc etc
muc
"Retired" Association of Marine Technicians...
Replace the o-ring on the drain bolt. If you try to reuse the old one it will most likely get cut on reassembly.
tlewis1
Pretty sure your gonna need a special tool to pull the second prop off.....
