Re: Wot ?????
More than likely, it was the latter, and it was most likely in the "prop" forum. Every motor will have "Manufacturer's Specs" as it applies to a WOT range, and if you're motor is not reaching those specs, then something is obviously wrong. Without knowing that, you could be damaging your motor and the problem won't surface until it's "too late". Of course, over-revving is just as big of a concern, if not bigger.
However, for optimal longevity, "cruising RPM" should be the dominant range. I've always been a "sound" person, even though I have a functioning tachometer. Not that I ignore the tach, but I can almost tell you with a couple hundred what RPM we're running just by listening to my outboard. It comes with time and use, and you'll find you will be doing the same eventually. I think we call boats "girls" because they are a lot like them in that we tend to know that "when the tone changes" we might be better off paying attention, lol.
