wot rpm 4200 78 johnson 85hp
tyl
I have a 17.5 sea nymph aluminum runabout with a 1978 Johnson 85hp manual tilt. I am running a 17p stainless prop it has had carbs rebuilt ,new tanks, new lines new coils, new powerpacks,new fuel pump . compression is 120 on all cylinders.It cruises at 3400 24 mph and top speed is 33 at 4200. with 2 people and 2 batteries 2 full 6 gallon tanks.Does anyone have a similar setup does this sound normal and tach not right or do you think I have another problem. I tilted engine either way and the tilt pin hole is third from bottom and boat runs the best.It runs good and starts good. I worry the rpms are too low. One other thing the idle screw is almost maxed out I don't know if that makes a difference.
jakedaawg
Do yiu have soft spots in the floor and waterlogged floatation?
Have you done a compression test?
Have you preformed a cylinder drop test?
tyl
compression 120 on all 4 cylinders all drop about 200 rpm when disconnected.floor is
good
jakedaawg
Have you ever been able to get it to full rpm with the tach you are useing?
tyl
No the tach is an hour meter/tach it seems to be accurate but may try another tach. I was hoping someone with a 85hp johnson or evinrude could tell me what they are getting or am i expecting too much from an old motor.
Baylinerchuck
I have the same motor, 85ML78C. Mine has a 13-3/4 x 15 prop. I used to have it on a 16' bayliner capri and also set the pin in the middle hole. I put a HydroStabilizer on it because it had a hard time getting on plane with 4 adults in the boat. The fin also improved performance pulling towables. 5000 rpm is max WOT and mine would run around 4800 WOT with the stabilizer. Max speed with 2 adults, 2 kids was about 33mph. That is a very good 2 stroke motor. I upgraded a little and put an 87 90hp Johnson with trim tilt on the same boat. Max speed now with trim on that 90hp motor is 42mph. What a difference trim makes!!!😎
Baylinerchuck
Also the idle screw on my 85 is also about maxed out. Nature of the beast on that old hog I suppose.
jimmbo
If your engine is in tune and the carbs are opening fully, you are over propped. Your engine WOT RPM range is 4500 - 5500. Improper engine trim will lower rpm. Is it running an all cylinders?
Your rpms don't appear out of line for the speeds you are reporting with a 17 in prop.
When the carbs were rebuilt was the timing checked, and a carb-ignition sync done?
tyl
I have manual tilt when i moved it out 1 hole it took longer to plane out rpm rose about 400. (4th hole out) no speed increase. Timing at idle 4 degrees carb sync is good as far as i can tell the boat runs perfect it is just slow
