wot range and volt output on 88 120 evinrude
flrfh213
i am told wot is 5000 to 6000 for my '88 evinrude I am told by others it is 5600 max. also what should volts be @ battery with multi-meter, I am getting 12.1 to 12.3
steelespike
Welcome to the prop forum.There is a Evinrude/Johnson Forum for service questions.
Sometimes we can help evaluate your performance here in props and help figure if its motor /boat issue or a prop issue.
The motor develops its hp at 5000 and the range would be 4500-5500.
Voltage at about 1500 rpm would be 13 to 14 volts.
Don't rev too high in neutral as it could trigger a runaway. 12.1V etc is standing voltage.
flrfh213
thank you for the information i apologize for putting it into wrong area did not realize I was in the prop section
