jaysnewboat
Thread starter- Joined
- Jun 26, 2010
- 4
I am having a problem with my mercruiser inboard 4 cylinder when I throttle up with no load(neutral) the engine revs fine. As soon as I put a load on it I throttle up and it revs up for like 45 seconds and then the engine bogs right down?? I can run at low throttle engine runs fine but as soon as I WOT the engine bogs right down. I have changed all the regular items points, condenser, coil, plugs, wires fuel filters etc. Even replaced the Carb with a factory rebuilt. Still having this problem. Can someone please give me some information on how to do a complete timing alignment. I have a feeling that the all the components are not set to top dead center because when I was adjusting the timing way out of scope seemed to make it run better.
Thank you in advance.
No pun intended.
No pun intended.
