WOT on 84 evinrude 115 ????
crazy charlie
I recently bought a 17ft. Mako with a 115 evinrude 1984.It runs great and the compression is great.I think it may have the wrong prop on it because it takes a little while to get on plane and then goes like a rocket and runs at about 4200 rpm but has way more left to go,over 5000 I would say.At about 37-3800 it can begin to come off plane.Cant find #s on prop and I tried a doel fin.Any Ideas on the wot range??? Charlie
D
DJ
Guest
Re: WOT on 84 evinrude 115 ????
Crazy,<br /><br />The operating range for that engine is 4500-5500.<br /><br />You do not want to "lug" it, as you are doing.<br /><br />I would prop it to run about 5500 with a very light load. That will put you around 5K with a moderate to heavy load.<br /><br />You can figure that each inch of prop is worth 200 rpm's.<br /><br />I would start with a 13 1/4" X 15". That is a heavy boat.
KennyKenCan
Do what djohns19 say's, because you definitly have the wrong prop on there!
crazy charlie
Thanks for the reply guys,I did not realize the 115 was designed to run at that high rpm.My other boat is a larger i/o and at3400 rpm I am moving nicely.The problem may be me .I usually back off the throttle when it gets near 4500.I guess I shouldnt.I will have to peg it to see if I top out at 5500. Charlie
